Tick over
- Ninja
Tick over
28 Jan 2021 08:38
Hi all, refitted my carbs, after a bit of a refurb, float levels, sync ect, set air screws 2 1/2 turns out a quick blast up the road to warm her up went really well re set the idle, up the road again and idle had increased quite a bit, any views
Re: Tick over
28 Jan 2021 09:35
Did you have to use the "choke" to start & warm up the motorcycle?
ps: it helps to mention what model it is.
Re: Tick over
28 Jan 2021 09:41
Mystery, what happened to zed1015’s post. He stated air screws should be about 1 1/4 to 1 1/2 out, also asked what bike.
I’m not crazy I saw it and now it’s gone?
- Ninja
Re: Tick over
28 Jan 2021 09:43
Oops apologies 77B1 and yes it needs choke to start and then I can drop lever halfway for a 2000 fast idle.
- zed1015
Re: Tick over
28 Jan 2021 10:10Mikaw wrote: Mystery, what happened to zed1015’s post. He stated air screws should be about 1 1/4 to 1 1/2 out, also asked what bike.
No! you're not crazy.
Started the post assuming it was a 900/1000 then quickly searched Ninjas posts and saw it's a 650 for which 2 - 1/2 turns out is correct so deleted it.
