1980 LTD 1000 Jetting
  • CopterDr
  • CopterDr's Avatar Topic Author
17 Jan 2021 13:45
#841893
Asking what you guys think would be a starting point for jetting a stock 1980 LTD 100 equipped with a Kerker 4in1 exhaust. Just purchased the bike along with a new Kerker.
  • Mikaw
  • Mikaw's Avatar
Re: 1980 LTD 1000 Jetting
17 Jan 2021 15:45
#841904
If it has stock air box no jetting should be necessary. Why do you want to re-jet? Is the bike not running well? You Have to do all maintenance adjustments first before you can think about tuning. Valve lash, timing, compression test. Maybe the carbs just need a good cleaning. Check that you have a fully charged and in good condition battery. Aslo need to know you have 12.6 volt at the primary of the coils... lots to check before you try to tune.
  • Mikaw
  • Mikaw's Avatar
17 Jan 2021 15:47
#841905
This manual should be close enough to get you in the ball park
kzrider.com/modules/ServiceManuals/Kawas...Service%20Manual.pdf
  • hardrockminer
  • hardrockminer's Avatar
17 Jan 2021 16:10
#841906
I have an '80 LTD. Right now it has a Z1 airbox and a 4/1 exhaust. I have a set of '76 carbs on it with stock jetting. It runs just fine.
  • CopterDr
18 Jan 2021 07:11
#841919
Thanks for the input. it helps alot.
