Carburetor holder o-ring 92055-1233
  • Kurila
  • Kurila's Avatar Topic Author
17 Jan 2021 03:05
#841856
Hello, maybe someone have answer.Bought new carb holders oem part number 16065-1110 but it came without o-rings witch oem number is 92055-1233 maybe someone have parts cataloge and can tell me what dimensions o-ring is?
  • Nessism
  • Nessism's Avatar
Re: Carburetor holder o-ring 92055-1233
17 Jan 2021 05:04
#841859
Sorry, I don't know the answer. In industry O-ring sizes are defined by cross section (CS) and inside diameter (ID.) I also know that for that application it's critical to use Viton O-rings. Buna N or Nitrile O-rings will fail due to heat.
  • Mikaw
  • Mikaw's Avatar
17 Jan 2021 09:27
#841873
They appear to be available at Partzilla
www.partzilla.com/product/kawasaki/92055-1233
  • Kurila
18 Jan 2021 06:28
#841916
Yeah i found some places they sell this , but in different continent and custom charges :D for this price i think will buy tourmax manifolds what goes without those pricy o-rings. Thanks for your help!
  • Nessism
  • Nessism's Avatar
18 Jan 2021 07:38
#841921
You can always measure. Use calipers and measure the ID of the ring groove, then figure out how thick of a ring you need. The ring should sit proud of the groove by about 1.25 mm. I'm not sure where you live but most locals have sources for O-rings.
