Rough idle on cold start help
  • gebbeth
  • gebbeth's Avatar Topic Author
31 Dec 2020 03:53
#840898
Hi guys,
Just got a kawasaki ZL400 eliminator 1986 (or so).
I have issues during cold starts. It revs all the way to 5000rpm (unstable) with choke fully on whereas it is supposed to be 2500 rpm according to the user manual. It's shown in the video here:
Spark plugs are new, carburator is clean, hoses between carb and engine are checked.
This is when it warms up a bit. Indrove it around for 5-6 mins:
Note that I adjusted the idle at ~1200rpm after the hot idle video. Also note that the colder it is outside, the rougher the cold start.
User manual: drive.google.com/file/d/1uPIc3wHxzPSWRmi...eE/view?usp=drivesdk
What could be causing those crazy rpms during cold starts? Could it be vacuum leak? Could it be a bad coil? Could it be moisture in the engine?
Thanks.
Re: Rough idle on cold start help
31 Dec 2020 06:59
#840905
Could it be "with choke fully on"? Ed
  • TexasKZ
  • TexasKZ's Avatar
31 Dec 2020 07:23 - 31 Dec 2020 07:34
#840907
The most likely culprits are
Vacuum leaks
Throttle or choke cables dirty, corroded, unlubricated
Clogged pilot circuits in the carburetors
Vacuum leaks can come from either end of each hose, plus from the devices connected to them . For example, if the valve that controls the PAIR system has a torn diaphragm, the vacuum hose will introduce additional air into that carburetor, causing a lean condition. The carb holders and intake boots must also seal perfectly. Have you checked the condition of the air filter?
The pilot circuits in the carbs consist of several tiny passageways that are easily clogged. If the person who cleaned the carbs did not carefully check each and every one of them, they can still be clogged, even after ultra sonic cleaning. An E string from a guitar does a nice job of clearing them. Sometimes an amateur carb cleaner will try to compensate for clogged pilot passageways by turning the idle mixture screws too far out and raising the idle so that the carbs are pulling some fuel from the main jets at idle. This creates all sorts of crazy behavior, like really wild rpm when the choke or enrichener is used.
The cables need to operate very smoothly, without any hesitation, or tight spots. Cable Life makes a really nice tool for this, and it is cheap. Z1Enterprises sells it.
www.z1enterprises.com/yamaha-xs650-cable...ubrication-tool.html
Last edit: 31 Dec 2020 07:34 by TexasKZ.
The following user(s) said Thank You: gebbeth
