TK-22 Carburetors
  • Wagner
  • Wagner's Avatar Topic Author
TK-22 Carburetors
29 Nov 2020 05:29
#839160
Hello. I have a 1981 KZ550 LTD that I am fixing up. I had the carburetors apart and cleaned them, bench tested the float bowl fuel height, and did a mechanical sync. Unfortunately the two middle carburetors are dripping very slowly out the bottom bowl drains. would this be a float valve, bowl fuel height issue, or bad drain screws. I'm new to the carburetor scene so any help wold be appreciated. Thanks.
  • hardrockminer
  • hardrockminer's Avatar
Re: TK-22 Carburetors
29 Nov 2020 06:26
#839164
I think either your float height is incorrect or you have worn float valves. Most likely the latter.
  • Nessism
  • Nessism's Avatar
  • Away
29 Nov 2020 10:41
#839186
hardrockminer wrote: I think either your float height is incorrect or you have worn float valves. Most likely the latter.
Agree. Also if your float bowls have overflow tubes inside you should inspect them closely to make sure they are not cracked.
  • TexasKZ
  • TexasKZ's Avatar
29 Nov 2020 13:54
#839204
Lou ( loudhvx)has assembled quite a bit of information about the 550, including a bunch on the TK carbs.
www.kzrider.com/forum/8-about-the-site/600635-signature#702657
