GPz1100 fuel filter Q
  • slayer61
  • slayer61's Avatar Topic Author
  • KZR FLAG RELAY CARRIER #62
23 Nov 2020 13:02
#838792
Alright y'all with stockish fuel injection, what fuel filter are you using? The OEM looks like
Is there anything even remotely close in size & shape?
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: GPz1100 fuel filter Q
23 Nov 2020 15:50
#838799
Long time ago I read about in a GB bike forum, some Japanese car (Toyota, Mitsubishi,...?) use the same fuel filter design for the half of the Kawasaki prize.
  • riturbo
  • riturbo's Avatar
24 Nov 2020 05:55
#838829
Been using the stock filters still available from kawasaki. Get them at my local dealer .
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
  • TexasKZ
  • TexasKZ's Avatar
24 Nov 2020 06:06
#838831
You can also order it through Partzilla.
  • slayer61
24 Nov 2020 06:55 - 24 Nov 2020 06:56
#838836
TexasKZ wrote: You can also order it through Partzilla.
When I looked on Partzilla, they say the wait time is over 200 days! :dry:
riturbo wrote: Been using the stock filters still available from kawasaki. Get them at my local dealer .
That's good news. I'll keep that in mind!
Last edit: 24 Nov 2020 06:56 by slayer61.
  • TexasKZ
  • TexasKZ's Avatar
24 Nov 2020 15:30
#838886
I looked just now, and it says ships in 3 - 4 days.
  • slayer61
25 Nov 2020 10:07
#838922
TexasKZ wrote: I looked just now, and it says ships in 3 - 4 days.
Well, you're absolutely right! Maybe they found a more "local" source for the filters! :)
  • ErikN
  • ErikN's Avatar
30 Nov 2020 14:36
#839242
I just had a factory original filter delivered today from Babbitts Online.
The bigger problem is the magic fuel hose between the fuel filter and the fuel pump. It’s only a few inches long, makes 2-90 degree turns and increases in diameter from 6(?)mm to 10(?)mm.
I have searched online in the US and Europe, not available anywhere.
Has anyone come up with a clever solution? Adapters?
1983 GPz1100
1983 GPz1100
1984 GPz1100 (parked in Stockholm)
  • Mikaw
  • Mikaw's Avatar
30 Nov 2020 17:56
#839249
ErikN wrote: I just had a factory original filter delivered today from Babbitts Online.
I vaguely remember seeing a post recently ( last six months) were they found a section of an auto hose that fit. Problem was it was a rad hose and other members had concerns about fuel attacking the rubber... that’s all I got.
  • riturbo
  • riturbo's Avatar
01 Dec 2020 05:33
#839257
Same issue on the 750 turbo . The line is NLA . Did a search on there .Many different solutions . Pick your poison.
www.750turbo.com/forum/search.php?st=0&s...words=fuel+pump+hose
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
