Engine starts and idling when choked, dies trying to rev up
  • Geshka
  • Geshka's Avatar Topic Author
07 Nov 2020 15:07
#838221
Hello there.
I am trying to get back to life donated to me kz 400. model 1978 I checked ignition and it seems to be OK, compression is fine as well, so here is the problem ...
Engine starts fairly easily and idling quite OK , howewer when I am trying to rev it up it dies immidiately. I beleive it is carb issue - just cannot pinpoit it.
Any help will be appreciated.
Kawasaki KZ 400 1978
  • Nessism
  • Nessism's Avatar
  • Away
Re: Engine starts and idling when choked, dies trying to rev up
07 Nov 2020 16:08
#838223
Yup, most likely carbs. They need to be spotless and connected to airbox and engine with airtight connections or the bike won't run right.
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
09 Nov 2020 05:40
#838275
You probably need to thoroughly clean the carbs.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • howardhb
  • howardhb's Avatar
  • God, I trust
11 Nov 2020 12:47 - 11 Nov 2020 12:49
#838349
Yes, remove and clean the carbs
Get a piece of metal guitar string (the type that is coiled) and pass it through all the jets and passages.
Then blast with some carb cleaner.
'81 GPz 550 D1
'82 Yamaha YB100 Fizzie
Last edit: 11 Nov 2020 12:49 by howardhb.
  • loudhvx
  • loudhvx's Avatar
12 Nov 2020 11:43 - 12 Nov 2020 11:46
#838388
In addition to what the others said, check out the rubber diaphragms very closely, especially in the crevice where the rubber meets the slide. Pinholes will prevent the slides from raising properly.
Last edit: 12 Nov 2020 11:46 by loudhvx.
