Z1 airbox '77 KZ1000 info
  • mafd2
  • mafd2's Avatar Topic Author
31 Oct 2020 10:12
#838041
I found a few threads that the Z1 air box will fit the '77 KZ1000. Does anyone have any pics of the setup? Will the box fit with the KZ side covers or do the covers need to be modified? Thanks in advance guys.
  • hardrockminer
  • hardrockminer's Avatar
Re: Z1 airbox '77 KZ1000 info
31 Oct 2020 11:15 - 31 Oct 2020 11:17
#838042
I did this on my 1980 KZ1000, which shouldn't be any different than yours. You can see in the following photos how it fit. I have no support under mine, but it doesn't seem to be an issue. A Z1 has a horizontal support underneath the air box. I think the Z1 airbox supplies more air than a standard setup so be prepared to richen up your fuel a bit to compensate.
Attachment IMG_2032.jpeg not found
Attachment IMG_2039.jpeg not found
Last edit: 31 Oct 2020 11:17 by hardrockminer.
  • mafd2
31 Oct 2020 11:25
#838044
Thanks for the fast reply and pics. I sent you a pm so disregard. Does the crankcase vent tube fit good and the same height?
  • hardrockminer
31 Oct 2020 11:41
#838046
Yes, it fits fine. But as I mentioned earlier, there is no support under the airbox like there is on a Z1. It would be easy to make one though. I was just too lazy.
The following user(s) said Thank You: mafd2
  • mafd2
31 Oct 2020 12:06
#838047
I appreciate the info. I'm sure I can figure out some kind of support.
  • Zeerx
  • Zeerx's Avatar
01 Nov 2020 15:27
#838111
I have a Z1 air box on my KZ1000 and it works great. VERY easy to remove the carbs....plenty of room. There is some support as it rests on the battery brace behind. The oil breather pipe provides a little also........no problem at all. Side covers are no factor.
Attachment C22F9356-53B4-4424-A06C-0A1F03642305.jpeg not found
‘78 KZ750B, ‘12 F150 (Ford)
  • mafd2
02 Nov 2020 06:03 - 02 Nov 2020 06:05
#838128
Thanks for the info and pic. I've been looking at pics of KZ's with Z1 air boxes. I surmise the Z1 uses a different filter than the KZ? Here's a 'pic of a '76 I found.
Last edit: 02 Nov 2020 06:05 by mafd2.
  • hardrockminer
05 Nov 2020 07:56
#838138
Yes, the air filter is different.
