FLOAT HEIGHT ? 28mm pumper 79 kz1000b
  • Jerryvan
  • Jerryvan's Avatar Topic Author
  • Send it
29 Oct 2020 12:49
#837959
Anyone know the required float height for a kz1000b (79 28mm pumper) carbs? Changing jets best look at floats too thanks....
Kz750 (81)
Kz1000 (79)
3 Kz650 (2-79's)
1 650 CSR for parts
  • Nessism
  • Nessism's Avatar
Re: FLOAT HEIGHT ? 28mm pumper 79 kz1000b
29 Oct 2020 14:03
#837962
Float height is just an estimate. Key thing is the fuel level which is about 3mm from the gasket surface. A lot of the aftermarket needles have weak springs, which increases the fuel level. That said, if forced to guess I'd say a float level of about 24mm.
The following user(s) said Thank You: Jerryvan
  • hardrockminer
  • hardrockminer's Avatar
29 Oct 2020 15:53 - 29 Oct 2020 16:06
#837968
The float height is 26 mm. The fuel level, measured from the bottom of the carb body to bowl flange is 4 mm. An easy way to set floats, and to check your float valves can be found here.
www.kzrider.com/forum/forum-index/3-carb...n-setting-fuel-level
Edited to add that if you change the float valves be sure to buy quality. I use Keyster for carb replacement parts but OEM would be even better if you can find them.
Last edit: 29 Oct 2020 16:06 by hardrockminer.
  • Nessism
  • Nessism's Avatar
29 Oct 2020 16:35
#837971
Agree with buying quality float valves.
If in the US Dennis Kirk has great prices on Mikuni brand jets and float valves. Kawasaki used non-standard Mikuni sizes for many of their float valves though. For example, I think they used a 2.3 for many of the big KZ's where the Mikuni parts come in .5 increments. 2.0's are safe though, considering Suzuki used that size for their GS1000.
