Idle on 3 cyls
  • Evobobber
  • Evobobber's Avatar Topic Author
Idle on 3 cyls
18 Oct 2020 01:17
#837116
Hi guys.
My 79 kz650sr idles on 3 cyls. No 2 exhaust stays cold but if i pull the ht lead off it does make a slight difference to engine note. Revs drop a bit.
Does this sound like a float set too low?
Thought id ask before i pull them apart.
Thanks guys.
  • zed1015
  • zed1015's Avatar
  • Away
Re: Idle on 3 cyls
18 Oct 2020 01:32 - 18 Oct 2020 01:35
#837118
Pulling the lead on 2 will affect the spark on 3 that's why the revs drop.
If it's only running on 3 cyls at idle and on all 4 over that then unless it's a faulty plug it's most likely a blocked or partially blocked pilot circuit or pilot jet.
If your carbs are the pilot fuel screw type then the needle tip of the adjustment screw could also have broken off and be blocking the fuel orifice in the base of the venturi.
Last edit: 18 Oct 2020 01:35 by zed1015.
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
Re: Idle on 3 cyls
18 Oct 2020 08:15
#837137
Not saying this is your issue, but I have read about issues with a vacuum petcock allowing way too much fuel to enter #2 via the vacuum take off on that carb (torn diaphram) causing #2 to be flooded and not running.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • Evobobber
Re: Idle on 3 cyls
18 Oct 2020 09:10
#837139
Cheers for that. I'll have a nose at that.
Thanks
