81 kz650 csr jetting
  • sean1980
  • sean1980's Avatar Topic Author
08 Oct 2020 14:39
#836416
im sure this has been asked...but im going to ask anyways,...i have an 81 650 csr that has pod filters and a wrapped kerker 4 into 1 exhaust. I bought it this way and I know the carbs were never jetted. So I purchased a stage 3 jet kit from z1e. My question is has anyone used one of these before? Which grooves should the clips go in? Does the carb have to be shimmed as well? The instructions that came with it came incomplete and are referencing charts that I didn't get with it. But on one of the very blurry pages it says that sometimes the clips have to be in this groove plus shimmed. Im curious if anyone out there has done this successfully and what was the right setup?
81 kz650 csr
81 kz1000 csr
09 kz versys 650
  • zed1015
  • zed1015's Avatar
Re: 81 kz650 csr jetting
09 Oct 2020 11:10 - 09 Oct 2020 16:46
#836468
You should have just bought these air corrector jets.
Just fit and forget and go up a couple of sizes on the main and that's it.
Lifting the needles is crude and the wrong way to do it and adds fuel to areas that don't need it.
www.kzrider.com/forum/23-for-sale/611992...-round-slide-mikunis
Last edit: 09 Oct 2020 16:46 by zed1015.
