Best carb synch tool on a budget please?
Re: Best carb synch tool on a budget please?
10 Sep 2020 03:30 - 10 Sep 2020 03:30
Here's what I use and they work really well.
Years ago I had a set of these (below) and they were crap; very inaccurate as readings were not at all consistent!
Last edit: 10 Sep 2020 03:30 by 650ed.
- asphalt900
10 Sep 2020 03:39
Warren, that is clever and balls on accurate, no pun, ha. I used to do a lot of footers and retaining walls years ago, had all the lasers for different directions. But.. if going around a blind corner used the ole clear tube filled with Gatorade trick. Perfect in simplistic design and 100 percent accurate.
The following user(s) said Thank You: Warren3200gt
10 Sep 2020 05:50 - 10 Sep 2020 05:52
This is from another member. Not sure where he bought it but look similar to the eBay sold dial your talking about. These might have just had a gorilla for a mailman but still be wary of cheap eBay items. The ol’ Saying goes you get what you pay for.
I use the Morgan Carbtune.
Last edit: 10 Sep 2020 05:52 by Mikaw.
- asphalt900
10 Sep 2020 08:22
Cannot people waste their money on those cheap individual analog gauges on a blue tin plate?? Biggest POS ever made. i and everyone could just as well do it by ear. The only redeeming fact is they come with the adaptors for Suzuki and some Hondas. I have an unused Mercury carb stik somewhere but no Mercury. Can you even buy Mercury anymore??? Or would a person need a special permit and background check?
- ckahleer
10 Sep 2020 08:29
Are the cheap dial gauges not adjustable?. Can you hook all gauges to a 5 port fitting, run them to one carburetor and adjust all 4 to match. It makes no difference if they read vacuum accurately, as long as they are consistent.
1997 ZL600
94 KE100
82 KZ305
74 TC185
94 KE100
82 KZ305
74 TC185
- Warren3200gt
10 Sep 2020 08:39 - 10 Sep 2020 08:48
You can do that, they have valve in the vacuum tube similar to the sort of thing used in aquarium air supply or the ones I saw did, only trouble is next time you use them they will need syncing again. You can connect dial 1 to carb 1, take reading, disconnect, reconnect to the same carb and get a different reading. They are a total waste of money.
Last edit: 10 Sep 2020 08:48 by Warren3200gt.
- asphalt900
10 Sep 2020 08:42
Yes but you would need to remove the face caps and calibrate at the range of functional operation. I think those are superglued on. I had a set i had gotten from ww grainger and those you could calibrate from a single vacuum source so they all matched at a certain range.
10 Sep 2020 08:59
Kaylinator is the member I pulled the picture from. He said like asphalt900 mentioned, he would have had to pull the needles off to try to calibrate.
10 Sep 2020 09:02 - 10 Sep 2020 09:02ckahleer wrote: Are the cheap dial gauges not adjustable?. Can you hook all gauges to a 5 port fitting, run them to one carburetor and adjust all 4 to match. It makes no difference if they read vacuum accurately, as long as they are consistent.
The problem I had with the cheap gauges was that the reading on one of them was WAY off and fluctuated badly. That gauge was not usable at all. Of course that then made me question whether or not the readings on other gauges were consistent or accurate enough to be useful. I have not had that or any other problems with the better set of gauges. I've hooked them up to different carbs on the bike to check them out and they seem to be very consistent. Ed
Last edit: 10 Sep 2020 09:02 by 650ed.
10 Sep 2020 09:08
Asphalt900, I’m sure you could get Mercury if you claimed you needed it for a peaceful protest. :evil:
- loudhvx
10 Sep 2020 09:30
Some places were still selling mercury as available, but it doesn't last long.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- asphalt900
10 Sep 2020 10:20
Just had a read on Your attached KZ550 Valve Train precautionary measures loudhvx, Very Informative, Thank-You! I don't see a lot of the small bore Kawi's but Now i Know where to go to gainer info if needed!
