Raising needle to correct hesitation and low speed surging
- ckahleer
07 Sep 2020 21:20
I recently corrected off idle hesitation and low speed surging on two bikes, an 81 CB650 and an 82 KZ305, by raising the carburetor needles about .080".
Carburetor jetting was stock and stock bikes.
My question is why would this be necessary? Could slide springs become weaker or diaphragms less pliable as carburetors age?
1997 ZL600
94 KE100
82 KZ305
74 TC185
94 KE100
82 KZ305
74 TC185
- Matt bx
Re: Raising needle to correct hesitation and low speed surging
08 Sep 2020 11:57
To me this sounds like a lean condition in the pilot system. Maybe raising the needle enriched the air-fuel mixture by allowing fuel to be metered from the main while at low RPM/Part throttle.?
- gd4now
- Denco where did you go?
08 Sep 2020 12:34
It could be parts are not what they were when new. It could also be the bikes were jetted lean from the factory and now that fuel is not what it was in the 80s could also be playing part in this.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- loudhvx
08 Sep 2020 17:32 - 08 Sep 2020 17:32
I've had to do this recently as well, on a bike that was running perfectly fine prior.
When I originally jetted the bike 13 years ago, i was interested in jetting it for fuel economy in the part throttle position. So I went about as lean as it could go while still running perfectly smooth. In the last few years it had started to run seemingly leaner. I suspect the difference is that I used to be able to get 100% gasoline. Then it went to 5% ethanol. Now 10% ethanol is about the lowest I can find around me.
For me the change was about .2 to .3 mm on the needle. That is only about .007". Your change of .080" is like 2 mm, which is a huge change.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 08 Sep 2020 17:32 by loudhvx.
