1984 ZN100 LTD Carbs
  • aphilbert
  • aphilbert's Avatar Topic Author
26 Aug 2020 15:27
#833755
1984 ZN1100 LTD, Looking for help finding Complete carb rebuild kits + manual. Anybody? Thanks
  • Nessism
  • Nessism's Avatar
  • Away
Re: 1984 ZN100 LTD Carbs
26 Aug 2020 16:42
#833756
You might want to read through this before ordering a bunch of expensive (and often inferior) aftermarket carb parts you might not need.
zeus.mtsac.edu/~cliff/storage/gs/Mikuni_...Rebuild_Tutorial.pdf
The following user(s) said Thank You: aphilbert
  • martin_csr
  • martin_csr's Avatar
27 Aug 2020 06:09 - 27 Aug 2020 06:13
#833781
I've never seen a pdf manual for the ZN1100, so you'll probably have to get one off of EB.
Search for KZ1100 Shaft Manual & get one that covers your year. They're usually kind of pricy, but you might find one at reasonable cost.
My carburetors are different, but I just replaced gaskets & o-rings.
If you need new vacuum slide diaphragms, JBM Industries might have them.
Last edit: 27 Aug 2020 06:13 by martin_csr.
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
27 Aug 2020 18:38 - 27 Aug 2020 19:10
#833818
The factory spec for those carbs have two different main jet sizes on cylinders 1 & 4. and 2 & 3.
I've often wondered the reasoning for that.
Kawasaki factory service manual part number 99924-1032-04 has service information for the 84/85 ZN1100's
One is currently listed on ebay for a good price and considering an offer! Item number 392832326067
Grab it!!! :ohmy:
ZN1100-B1 carburetor page near the back:
1982 KZ1100-A2
Last edit: 27 Aug 2020 19:10 by daveo.
  • aphilbert
27 Aug 2020 19:17
#833820
Much appreciated. Thank you
  • so stupiddad
  • so stupiddad's Avatar
28 Aug 2020 02:21
#833834
The reasoning is to try to maintain temps on all cylinders within spitting distance of each other, 1 and 4 cool better, rich runs cooler than 14 to 1 stoichiometric mix.
The following user(s) said Thank You: daveo, Scirocco
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
28 Aug 2020 06:46 - 28 Aug 2020 06:48
#833839
so stupiddad wrote: The reasoning is to try to maintain temps on all cylinders within spitting distance of each other, 1 and 4 cool better, rich runs cooler than 14 to 1 stoichiometric mix.
I have always run the same jet sizes in all four carbs, except air jets tried recently in my Flat Slides.
Is it typical to have main jets set up that way on Kawasaki fours in general?
:huh:
1982 KZ1100-A2
Last edit: 28 Aug 2020 06:48 by daveo.
  • so stupiddad
28 Aug 2020 14:14
#833872
Running the same mains in all 4 or all 6 isn't a real problem unless you run at high throttle and revs a great deal of the time. Specifying the slightly richer mains on inner cylinders is a durabiity tweak to cover track day and race use as well as normal highway riding.
