Z1R D3 Petcock
- 1980 Z1R D3
- A young gun with a taste for two-wheeled fun!
Z1R D3 Petcock
31 Jul 2020 06:47
Hi guys,
I was looking to see if anyone knows of a good place to buy a petcock for a D3 Z1R because after buying a supposed OEM one on eBay, it not only was not OEM, but also broken, as the fuel doesn't shut off after we turn it to the "OFF" position. We've tried to fix it several times with no success, so its time for a new one.
Thanks
Thanks
1980 Z1R D3
- Z1R rider
Re: Z1R D3 Petcock
31 Jul 2020 07:34 - 31 Jul 2020 07:39
I think it's the same as a D-1, I've been watching for 20 years and all I've found are the "Pingel" petcocks. They don't look stock but I've heard they are the best option. I've never tried one, just put up with my stock "weeper".
You might try on the Z1R owners Facebook page, some of the members have a bunch of parts squirreled away.
1978 KZ1000, Z1R
1999 250 Ninja race bike
2013 WR250F, fun in the dirt
Last edit: 31 Jul 2020 07:39 by Z1R rider.
- david richard
Re: Z1R D3 Petcock
31 Jul 2020 08:07
hi d3 can i ask the problem you had ,would it be the type when you remove the screw and pull the lever out of the body it has a cast barrel with 2 holes and a o ring ,which look very like the oe part ,but in fact dont ever shut off ,ask me how i know the oe tap has a white nylon barrel inside ,i had to get one from germany a couple of years ago ,at present there is one in the usa im not sure where you are but they are all the same d1 d3 good luck ,david
Re: Z1R D3 Petcock
31 Jul 2020 08:31
Appears that your petcock bung uses the 22mm jamb nut so if your not needing to be factory original then the single outlet Pingle would be a good replacement... I have one on my ‘78 1000 LTD and really like it....
- Highway Magician
Re: Z1R D3 Petcock
31 Jul 2020 08:40
No eBay APP ID and/or Cert ID defined in Kunena configurationKawasaki 51023-1007 TAP ASSY, FUEL, fits the following models and components:
Kawasaki Motorcycle 1981 GPz - KZ1100-B1 FUEL TANK
Kawasaki Motorcycle 1982 GPz - KZ1100-B2 FUEL TANK
Kawasaki Motorcycle 1980 Classic - KZ1000-G1 FUEL TANK
Kawasaki Motorcycle 1980 Z1R - KZ1000-D3 FUEL TANK ('78 D1)
Kawasaki Motorcycle 1978 Z1R - KZ1000-D1 FUEL TANK ('78 D1)
Kawasaki Motorcycle 1980 Z1R - KZ1000-D3 FUEL TANK ('80 D3)
Kawasaki Motorcycle 1978 Z1R - KZ1000-D1 FUEL TANK ('80 D3)
Here's the one you need:
Motorcycle builder since 1973. Master Tech. Current bike: 1982 GPZ1100B2.
