Upsizing Main Jets to Compensate for Pods
  • zed1015
  • zed1015's Avatar
Re: Upsizing Main Jets to Compensate for Pods
27 Jul 2020 11:46 - 27 Jul 2020 11:56
#831602
Raising the needle only richens and shifts the fuel pattern across the mid range bringing more fuel in earlier but it can only work with what the main supplies.
If the main is too small the needle can't produce any more fuel no matter how high it is lifted.
The old trick with the low end flat spot with pods was to up the pilot and lift the needle which is what i suspect is influencing your thinking.
This puts more fuel in the lean off idle mix to mask the flat spot but it also adds extra to the overall fueling giving an unwanted rich mix everywhere on up.
The air corrector jets reduce the air supply to the needle jet tube ( not the pilot jet ) at a specific point which targets the lean spot off idle but with a lesser fueling change than the pilot jet/needle method.
Above this the effect feathers off and doesn't heavily impact on the other fuel circuits .
Last edit: 27 Jul 2020 11:56 by zed1015.
The following user(s) said Thank You: hardrockminer
  • Rick H.
  • Rick H.'s Avatar
27 Jul 2020 12:16
#831609
Great topic and discussion guys! Thanks for all the information on this. Very interesting reading.
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
  • krazee1
  • krazee1's Avatar
27 Jul 2020 12:27
#831615
If the main jet is correct for WFO (3/4 throttle+) and you need to richen things up in the mid-range, that when you would raise the needle position. Needles with different tapers are also available I believe.
Mike
1974 Z1
1978 KZ1000 LTD
1976 KZ900B pile O parts
1980 KZ750E
  • hardrockminer
  • hardrockminer's Avatar Topic Author
27 Jul 2020 17:22
#831649
Thanks again zed1015. Apologies on the restrictor location. My mistake.
Do you have any experience with the range of increase in air supply through the carburetors with pods over stock air intakes? I am thinking it must be more than 10% more but that's just a guess.
