KZ1000 won't start after carb cleaning
  • Mikaw
  • Mikaw's Avatar
Re: KZ1000 won't start after carb cleaning
11 Jul 2020 11:06
#830374
Kidkawie wrote: Do yourself a favor and install a Dyna pickup.
+1
  • Rick H.
  • Rick H.'s Avatar
11 Jul 2020 11:21
#830375
TSK, TSK, TSK....Dyna's are for girls! Points and condensers are for men!!!
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
11 Jul 2020 11:43
#830377
Rick, be carefull. A lot of Dyna pussy´s reading here.... :laugh: :laugh: :laugh:
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
11 Jul 2020 15:02
#830392
Rick H. wrote: TSK, TSK, TSK....Dyna's are for girls! Points and condensers are for men!!!
Rick H.
You must send text messages via smoke signals.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • magilla
  • magilla's Avatar Topic Author
12 Jul 2020 05:35 - 12 Jul 2020 08:41
#830443
Well, the issues with the lighting circuits must have been related to the moisture, because when I started trying to track down the shorts, the voltages were back up to 12.5V on both of those circuits with no overheating of the fuses. It has been hot and dry here for several days. It was great to get the bike out again, I rode about 60 miles yesterday. I think I need to adjust the carbs. After riding about 30 miles, the bike seemed to be missing a little at idle, and I couldn't adjust the idle down any lower than about 2,000 rpm. The idle setting procedure in the manual is for the 26mm carbs. Mine are the 28mm carbs that don't have pilot screws on the bottom. There are adjusting screws on the tops, are these the pilot screws?
1979 KZ1000-B3 LTD
Carrollton, Illinois
Last edit: 12 Jul 2020 08:41 by magilla.
The following user(s) said Thank You: Oncle Raoul
  • F64
  • F64's Avatar
  • 81-KZ440D2
12 Jul 2020 08:16 - 12 Jul 2020 08:17
#830455
I'm glad the bike sorted itself out electrically.
Thanks for the update.
The others will be able to help you out on the fueling side. :)
81-KZ440-D2.
LIC, NY
Last edit: 12 Jul 2020 08:17 by F64.
