KZ1000 won't start after carb cleaning
  • magilla
  • magilla's Avatar Topic Author
Re: KZ1000 won't start after carb cleaning
09 Jul 2020 08:11
#830183
My ground connection is on the transmission, not the frame. Is that normal for a kz1000?
1979 KZ1000-B3 LTD
Carrollton, Illinois
  • F64
  • F64's Avatar
  • 81-KZ440D2
09 Jul 2020 08:13
#830184
Not really sure on the mounting point.
What is more important----is it a good ground electrically?
81-KZ440-D2.
LIC, NY
  • Mikaw
  • Mikaw's Avatar
09 Jul 2020 08:14
#830185
Yes that’s were battery negative is landed. Pull it and clean..,
I’m interpreting the “kill switch “ as the off/run switch on the Rh control. I don’t think he has addressed the ignition switch... I’ve heard of lots of problems with voltage caused within the ignition.
  • F64
  • F64's Avatar
  • 81-KZ440D2
09 Jul 2020 08:20
#830186
Magilla covered the ignition switch when he checked the fuse followed by the kill switch. He had no drop between those 2 points.
If he had 12 volts at the fuse then 9 volts at the kill switch, then yes...the ignition switch could be the issue.
81-KZ440-D2.
LIC, NY
  • magilla
09 Jul 2020 08:22
#830187
No I haven't looked at the ignition yet, I think it has to be closer to the battery or at the battery since I am not getting 12 volts anywhere except at the battery with the ignition either on or off.
1979 KZ1000-B3 LTD
The following user(s) said Thank You: Oncle Raoul
  • F64
  • F64's Avatar
  • 81-KZ440D2
09 Jul 2020 08:24
#830188
You did look at it.
You have to see where the switch sits on the schematic.
It sits between the fuse and the kill switch.
Your problem is most likely between the fuse and the battery or on the ground side.
81-KZ440-D2.
LIC, NY
  • magilla
09 Jul 2020 08:25
#830189
One other fact that might play a part in all of this is that while I had the tank and carbs off (intake ports were plugged) we had a 5" rain over the period of a few hours and everything was drenched. The bike is living on my patio right now so was not covered.
1979 KZ1000-B3 LTD
  • Mikaw
  • Mikaw's Avatar
09 Jul 2020 08:27
#830190
If he has battery voltage at the purple circle white wire and only 9ish at the purple square then the resistance is in the ignition
  • F64
  • F64's Avatar
  • 81-KZ440D2
09 Jul 2020 08:28
#830191
Always a possibility.
That's why we test.
81-KZ440-D2.
LIC, NY
  • Mikaw
  • Mikaw's Avatar
09 Jul 2020 08:32
#830192
Maybe read it wrong... he tested the fuses and only has 9.6... is that the same at the purple circle
  • F64
  • F64's Avatar
  • 81-KZ440D2
09 Jul 2020 08:33
#830193
He has battery voltage at the purple circle????????
I didn't see that stated.
81-KZ440-D2.
LIC, NY
  • F64
  • F64's Avatar
  • 81-KZ440D2
09 Jul 2020 08:36
#830195
Everything from the fuse to the coil is 9.6 on the positive side.
81-KZ440-D2.
LIC, NY
