Mikuni RS Flat Slide Accelerator Pump System
- Injected
Re: Mikuni RS Flat Slide Accelerator Pump System
26 Aug 2020 13:21
I just finished getting the remaining pins removed. I had to heat the head side post with a pencil tip flame from a brazing kit, put a wet rag over the float... one tap got them removed after the heating process.
I filed the pins down in my hand and de-burred the post holes, should have no issues in the future.
1978 KZ650B2 modified project
1981 Z50R Honda tow bike
- Injected
27 Aug 2020 07:24ayeckley wrote: My suggestion is to use .095” drill rod to make your own pins. McMaster-Carr 8890K132. I cut them long enough so that the inside walls of the float bowl hold them in place side-to-side. That way just a paper clip is all that is needed to remove them in the future. I’ve done this mod on several sets of BS34s as well (different diameter pin required).
Yes, that could be done but the bowls for these carbs have a funky shape, they all have the well for the accelerator pump so even if the stock pin is not pushed in all the way (orientated correctly) it will hit the connection to the well keeping the bowl from centering on the screw holes. I found this out when putting the bowls back on, sort of surprised me.
- ayeckley
27 Aug 2020 22:32
Hmmm. I didn’t have that issue for some reason.
1976 KZ900A4
1976 KZ900A4
1978 KZ1000A2
1983 ZX750 A1 aka GPz 750
1983 ZX750 A1
1973 CL350K4
1984 ZX1100 A2 aka GPz1100
1969 CT90
2006 Burgman 400
1976 KZ900A4
1978 KZ1000A2
1983 ZX750 A1
1973 CL350K4
1969 CT90
2006 Burgman 400
