vm28 carburetors missing parts
- mbcustom
01 Jul 2020 12:59
I bought remanufactured vm28 carburettors, I noticed that a bowl is missing, I was wondering if there was any version in which the bowl is not present or if a part is definitely missing. In the photos the missing part.
Re: vm28 carburetors missing parts
01 Jul 2020 14:11 - 01 Jul 2020 14:51
See triangle shaped diaphragm in the listing I posted, its call the Sensor diaphragm, notice the brass pin in its center... I have rebuilt 2 sets of the VM28 pumpers and neither needed that diaphragm. Appears yours doesn't either. That long pin has to install in a hole in the center of the triangle shaped boss on your carbs... There is no hole in the center of yours... Hopefully Zed1015 will reply and tell us what the sensor circuit is used for and on what carbs it used...
redlinecycle.com/Carb%20-%20Accel%20Pump.html
Last edit: 01 Jul 2020 14:51 by Mikaw.
- gd4now
- Denco where did you go?
01 Jul 2020 15:04
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
01 Jul 2020 15:16
gd4now... YES... thank you...!!!
01 Jul 2020 20:05 - 01 Jul 2020 20:06
I recently picked up a set of VM28's as a rebuild project and it doesn't have a cover over that triangle shaped area either. Pretty sure (hoping actually) no parts are missing.
Last edit: 01 Jul 2020 20:06 by Nessism.
- mbcustom
01 Jul 2020 23:46I have checked some parts diagrams, for example kz1000 4 ltd 1980 seems have the part, instead kz1000b3 1979 seems don't have.Nessism wrote: I recently picked up a set of VM28's as a rebuild project and it doesn't have a cover over that triangle shaped area either. Pretty sure (hoping actually) no parts are missing.
Probably there are different versions.
Here the pics of the 2 diagrams.
- kevski
02 Jul 2020 00:29 - 02 Jul 2020 00:35
The bowl is as it was cast without being drilled for the extra parts the way they should be on the 28mm pumpers, the bowl is generic and is also used on the 26mm pumpers with the second diaphragm fitted, which was a disaster for the 26mm carbs, i have the 26mm pumpers on mine and have modified the bowl so it effectively works the same way as the bowl on your 28's, so nothing to worry about your carbs are as they should be.
Last edit: 02 Jul 2020 00:35 by kevski.
- zed1015
02 Jul 2020 05:08
Only the VM26's have the triangular sensor diaphragm active.
All the 28's have it blanked / un-machined and no cap.
Your 28's are as they should be and have nothing missing.
02 Jul 2020 08:32
This is the Partzilla breakdown for the 1000 LTDB4. I have successfully used it for both rebuilds I’ve done without fail... not sure yours is correct... regardless you don’t need any additional diaphragms..
Thanks Zed1015
Thanks Zed1015
