bogs right off stopped position, everything else is good
- Charleslabri
23 Jun 2020 13:00 - 23 Jun 2020 17:16
Hey all!
Im having a problem thats been really hard to track down.
Bike bogs RIGHT off a stopped position, I really have to feather the clutch. But once it hits higher RPM, works fine.
It also takes about 3s to drop down back to idle RPM if i rev it.
No other noticeable performance gaps anywhere else.
Jetting is stock, Running stock airbox, stock air filter, the needle is 1/2 step richer than stock.
thoughts?
thoughts?
About 8 various model KZ650s..
Running KZs: 0
Running KZs: 0
Last edit: 23 Jun 2020 17:16 by Charleslabri.
- Charleslabri
Re: bogs right off stopped position, everything else is good
24 Jun 2020 09:49
no takers?
Running KZs: 0
Running KZs: 0
24 Jun 2020 10:05
My only observation is a hanging idle/rpm indicate a lean pilot condition
- Charleslabri
24 Jun 2020 11:06
if i let it idle and did a plug chop, would i be able to identify a lean condition?
Running KZs: 0
Running KZs: 0
24 Jun 2020 11:33
Maybe I should back up. Have you investigated the cables and throttle springs and linkage. Those if binding could result in similar conditions
- Charleslabri
24 Jun 2020 12:07
yeah, theres a little bit of slack, enough to ensure that there is not a hang on throttle accel.
Running KZs: 0
Running KZs: 0
24 Jun 2020 17:12
Have you checked for air entering through your manifold boots?
