Rebuild Kits
  • Pappaws76ltd
  • Pappaws76ltd's Avatar Topic Author
Rebuild Kits
11 Jun 2020 02:50
#827841
what is the preferred brand for VM26 rebuild kit.
Thanks All
76kz900ltd
  • Nessism
  • Nessism's Avatar
  • Away
Re: Rebuild Kits
11 Jun 2020 05:05
#827846
When rebuilding old carbs I endeavor to reuse as many of the factory parts as possible. Take the carbs fully apart and soak everything in carb dip then inspect for wear.
cycleorings.com sells an O-ring kit and you can get new float bowl gaskets from Z1 Enterprises. If your float seats and needles are worn you can get new Mikuni brand parts from Amazon. One thing to be mindful of when rebuilding those carbs is cracks in the fuel Tee rubber. Z1 sells replacements but the O-rings are a poor fit. I've found the O-rings from a Harbor Freight metric kit to have the right size or maybe the cycleorings kit has the proper size too (not sure.)
  • hardrockminer
  • hardrockminer's Avatar
Re: Rebuild Kits
11 Jun 2020 05:10
#827847
From my experience all of the kit rebuilders have deficiencies but I believe Keyster makes the best quality and most comprehensive rebuild kits.
  • shrap66
  • shrap66's Avatar
Re: Rebuild Kits
11 Jun 2020 05:57
#827849
+1 on OEM parts and the O-rings kit.
I did buy Keyster kits for my VM26 and they are very complete but pricey.
1979 KZ1000B3 LTD Glacier Green
  • hardrockminer
Re: Rebuild Kits
11 Jun 2020 08:19
#827873
shrap66 wrote: +1 on OEM parts and the O-rings kit.
Yes, and you get a lot of stuff you don't really need. I think they have the best gaskets, and they provide needle jets, which most other suppliers don't provide. But I don't need three pilots, six main jets nor four different needles. And I find their choke plungers are less than ideal...wish they had the little point on the bottom like OEM. Also wish they would supply new choke rubber seals.
  • zed1015
  • zed1015's Avatar
Re: Rebuild Kits
11 Jun 2020 09:12
#827880
hardrockminer wrote: And I find their choke plungers are less than ideal...wish they had the little point on the bottom like OEM. Also wish they would supply new choke rubber seals.
I can refurb the original plungers if anyone needs them doing.
I've custom built the tooling to make and insert full size ethanol resistant VITON seals in the original plungers without disturbing the rolled securing edge.
I can do all the VM series 4 cyl carb banks.
I have a listing on ebay offering the service worldwide but can do it cheaper if contacted direct.
The following user(s) said Thank You: Nessism, ErlingW
