Vacume line from carb to petcock. 2002 kz1000p
- Road Gnome
09 Jun 2020 08:45 #827663
by Road Gnome
Vacume line from carb to petcock. 2002 kz1000p was created by Road Gnome
So i recently put a new oem petcock onto my bike seeing that the previous owner placed an aftermarket one on there. So the kz1000p has a bank of 34mm mikuni bs carbs. Where do i hook the vacuum line to the carbs? One of the nipples used for syncing the carbs? If so Does it matter which one it is hooked to? Thanks yall !
- Thank you received: 1656
09 Jun 2020 09:55 - 09 Jun 2020 09:56 #827676
by martin_csr
Replied by martin_csr on topic Vacume line from carb to petcock. 2002 kz1000p
Yes, use one of the carburetor sync ports & it doesn't matter which one. on most KZs the vac line is connected to the #2 carburetor.
Last edit: 09 Jun 2020 09:56 by martin_csr.
