1977 KZ750 float adjustment
- Ramchargerjay
05 Jun 2020 17:34
How can I check the fuel level to adjust the floats if there’s no nipple to attach a hose to?
Re: 1977 KZ750 float adjustment
05 Jun 2020 17:42
Use the Slmjim method....take the bowl off and set the carb on a glass that is wide enough to allow the floats to move freely. Then open up the gas line.
- slmjim+Z1BEBE
06 Jun 2020 06:10 - 06 Jun 2020 07:09
hardrockminer refers to a method we successfully experimented with that we detailed in post # 825825. See the pics toward the bottom of post # 825825 here:
kzrider.com/forum/11-projects/609053-the-wounded-z?start=36
If you wish to use the clear tube method, there's almost certainly a removable drain screw in your carb float bowls. A suitable length of clear aquarium tubing can be "screwed" into the threaded drain screw hole. Trim the OD of the tubing into a short taper carefully & neatly for a liquid-tight fit if necessary.
Good Ridin'
slmjim & Z1BEBE
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
Last edit: 06 Jun 2020 07:09 by slmjim+Z1BEBE. Reason: Clarity
