Carb diaphragm
- robhartle82
Carb diaphragm
25 May 2020 15:05
Hey everyone. I just bought a 1980 kz440. When I disassembled the carbs I saw that the diaphragms on both carbs were completely shredded. Looking up OEM replacements I found that they're really, really pricey. Does anyone know of any good aftermarket diaphragms? Or anywhere I can get a decent set of oem ones for a reasonable price? Thanks!
Re: Carb diaphragm
25 May 2020 16:02
This is copy and paste from loudhvx in another post with the same question
The only aftermarket support the 440's have, luckily are new diaphragms for the carbs.
Very closely inspect them for rips right near where they attach to the slide. That is often the first area that rips.
If they have holes, that will cause bogging. There are many other causes for bogging, but that is one, and a common one on the 400/440's.
There is a place called JBM industries that makes diaphragms.
The following user(s) said Thank You: robhartle82
Last edit: 26 May 2020 06:37 by martin_csr.
