- Thank you received: 2
Fuel tap bench testing KZ1000 A
- Nyclocoengineer
16 May 2020 21:20 #825894
by Nyclocoengineer
Fuel tap bench testing KZ1000 A was created by Nyclocoengineer
Does anyone know how to bench test the stock fuel tap? Before I install the repainted tank I want to make certain the stock fuel tap. I tried to use a vacuum pump attached to the vacuum port. Well...I blew and sucked on the fuel ports but seemed to get closed air on each leg of the outflow ports.. What do you folks suggest? I thank you for your help!
- Thank you received: 1656
17 May 2020 06:04 #825904
by martin_csr
Replied by martin_csr on topic Fuel tap bench testing KZ1000 A
What's the history of the fuel tank & petcock? It sounds like the diaphragm is stuck in the closed position. You could remove the fuel tap lever, then apply vacuum to see if the diaphragm plunger moves.
- Nyclocoengineer
17 May 2020 10:29 #825923
by Nyclocoengineer
Replied by Nyclocoengineer on topic Fuel tap bench testing KZ1000 A
Hi Martin! I took the tap apart and while cleaning it out I found black "goo" like maybe the spray cleaner melted something rubber in the square part that the screws go through. Also I could not get air to pass through the 1/4 vacuum fitting until I probed it with tag wire and shop air.I managed to get it all cleaned out with shop air. The diaphragm Is in OK shape and I used a small amount of Permatex to seal it up. I'll try again this afternoon with the vacuum to see if I can duplicate the running condition.
17 May 2020 10:33 - 17 May 2020 10:36 #825924
by martin_csr
There should be an o-ring on the diaphragm plunger where it would contact the petcock body >> it may need replacing, especially if it's hard or flattened or something.
Last edit: 17 May 2020 10:36 by martin_csr.
- davido
- Thank you received: 292
17 May 2020 13:42 #825945
by davido
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
Replied by davido on topic Fuel tap bench testing KZ1000 A
Theres a very good tutorial floating around on restoring these taps. I think from an XS 650 site. worth having a look at it. Somebody here will have a link to it, Im sure.
Also a rebuild kit is not expensive.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- Nyclocoengineer
17 May 2020 19:27 #825978
by Nyclocoengineer
Hey thank you! I'll research the XS650 info. I think I'm going to install the Pingle fuel tap I have. I'll save the stock one for posterity...lol
John
John
