bowl gaskets
  • urankjj
  • urankjj's Avatar Topic Author
bowl gaskets
05 May 2020 11:28
#825051
Can you re-use float bowl gaskets if they are not damaged ? Thanks..
Re: bowl gaskets
05 May 2020 11:41
#825052
I have done that and I didn't have any problems. However, if the gaskets are really old they can get very hard, so if that's the case you may want to replace them. Ed
The following user(s) said Thank You: urankjj
  • martin_csr
  • martin_csr's Avatar
Re: bowl gaskets
05 May 2020 11:56 - 05 May 2020 12:14
#825056
When I rebuilt my carburetors, I rejuvenated the gaskets by soaking them in Liquid Wrench silicone spray lubricant & let them sit overnight in a sealed container. I didn't know this at the time, but the LW can said the product was good for paper gaskets or something to that effect.
ps: prior to installation, I probably let them air dry so that any solvents could evaporate.
Last edit: 05 May 2020 12:14 by martin_csr.
  • z1kzonly
  • z1kzonly's Avatar
Re: bowl gaskets
05 May 2020 15:14
#825074
Yes, I have. As long as they are good to go. No damage, nice looking. But if hard? Soak in a light petroleum oil, little gas mixture.
