Vm26ss 1977 kz1000 setting float height clear tube method
- Gdizard
04 Apr 2020 22:46
Can I set float height before I install the main jet , main jet needle ?
Thank you
Greg
Thank you
Greg
- kevski
Re: Vm26ss 1977 kz1000 setting float height clear tube method
04 Apr 2020 23:32
Yes it can be done, don't see the point though, may aswell wait until all parts are assembled unless there is a specific reason.
05 Apr 2020 14:22
I guess you could if your looking to get it done while your waiting on parts. My assumption would be the float level would be the same after jets are installed it would just take less fuel. I’m thinking of the old trick of putting bricks in the toilet tank. The float level doesn’t change just uses less water to fill the tank. I don’t see an issue.
The following user(s) said Thank You: Scirocco, Gdizard
05 Apr 2020 15:25 - 05 Apr 2020 15:26:laugh: :laugh: :laugh:I’m thinking of the old trick of putting bricks in the toilet tank:laugh
I would prefer water filled plastic bottles.:whistle: :whistle: :whistle:
Last edit: 05 Apr 2020 15:26 by Scirocco.
The following user(s) said Thank You: Mikaw, Gdizard
