80 kz440 Ltd carb hose question
  • Amenwetravel
  • Amenwetravel's Avatar Topic Author
27 Mar 2020 11:29
#821907
Hi y’all, new here and just got my first bike. 1980 kawasaki kz440 Ltd. so at the bottom of the carbs, there is no hose or cap or anything, slow dripping. I know nothing! Super newb, but I am determined to figure this out and do what I can to get her on the road. I got a new battery, started her up this morning, so she runs, just needs some care and cleaning and figuring out what all she needs.
KZ440 LTD 1980
  • TexasKZ
  • TexasKZ's Avatar
Re: 80 kz440 Ltd carb hose question
27 Mar 2020 13:20 - 27 Mar 2020 13:21
#821925
That dripping could be from the fuel level being too high. Could be dirty needle valves or improperly adjusted floats. Each carb should have a hose attached there that goes down between the engine and swingarm pivot. A factory service manual, some good metric wrenches and a set of JIS screwdrivers will make maintenance and repair much easier.
Last edit: 27 Mar 2020 13:21 by TexasKZ.
The following user(s) said Thank You: Amenwetravel
  • TexasKZ
  • TexasKZ's Avatar
27 Mar 2020 13:25
#821926
You can download a 440 manual from KZR. It is located in the Articles menu. I beleive it is the last one on the list.
