When I'm choking my engine, if I rev my bike the throttle sticks
  • Marskmil
  • Marskmil's Avatar Topic Author
23 Mar 2020 06:20
#821491
I'm not sure why but my throttle sticks only while I'm choking the engine. Once it warms up, I put the choke down and it doesn't stick anymore. I tried tightening and loosing the cables from the fine adjusters but that didn't work. Also, the throttle feels fine it snaps right back and there's a good amount of free play Any ideas?
Re: When I'm choking my engine, if I rev my bike the throttle sticks
23 Mar 2020 08:47 - 23 Mar 2020 08:54
#821503
When the choke lever is raised up the engine will rev higher than normal. That is normal and has nothing to do with the throttle cables. Instead of pulling the choke lever all the way up, without touching the throttle try lowering the choke lever some to bring the revs down. Also, it's not a good idea to rev the engine, especially when the engine is cold. Ed
Last edit: 23 Mar 2020 08:54 by 650ed.
  • TexasKZ
  • TexasKZ's Avatar
23 Mar 2020 20:00
#821546
Some epic stooopid in that video.
