Spacing on Mikuni RS-36
- richard-GPZ
21 Mar 2020 17:23
Been having trouble mounting a set of Mikuni RS36-D3 K on my 1983 GPZ-1100.
I measured the spacing of the intake manifolds on my GPZ and got 75-96-75.
The spacing on the Mikuni's are 77-93-77.
Has anyone got a fix so the carbs will fit better?
Thanks for any help you can give.
1983 GPZ-1100 completely stock
1983 Gpz-1100 hot rod build in process
Re: Spacing on Mikuni RS-36
21 Mar 2020 18:13
Looks like the carb spacing should be 73-93-73
www.partzilla.com/product/aftermarket/1812-MIKUNI-RS36-D3-K
- richard-GPZ
21 Mar 2020 21:34
Hope these pictures help to show the spacing problem I am having.
22 Mar 2020 04:42
The spacing is 77-93-77 and you have to use intake rubber boot with 42 mm ID to fit the RS36-D3-K carb set.
www.mikuni-topham.de/ENGLISHSITE/ENGLISH/Frame_English.html
- richard-GPZ
22 Mar 2020 07:29
Yes the spacing on the Mikuni carbs are 77-93-77 but the intake spacing on the head is 75-96-75.
22 Mar 2020 14:55 - 22 Mar 2020 15:00
Did you do double check the spacing on your injector throttle body?
Give me some time to do some meassurments tomorrow on my spare GPZ1100 UT head and throttle body for the spacing values.
Last edit: 22 Mar 2020 15:00 by Scirocco.
- richard-GPZ
22 Mar 2020 15:15
Thanks you for checking.
Unfortunately I sold my throttle body
- richard-GPZ
22 Mar 2020 16:19
Still Have the air box for the throttle body and it checks 75-96-75
- Dr. Gamma
22 Mar 2020 16:25
I don't have the time to go checking my notes and parts books.
But I believe you need to use 16065-1135 intake ducts on the Zx1100 head to mount up the RS36 Flatslides.
1986 RG500G 2 stroke terror.
- richard-GPZ
22 Mar 2020 16:43
I believe I have the right intake ducts I will have to check them.
But even with the right intake ducts the spacing I measured shows the carbs still don't match up by 2 to 3 mm.
Is that ok to have them off by that amount?
- richard-GPZ
23 Mar 2020 13:52
I checked my intake ducts and they are 40mm.
Will look into changing them out with 42mm ones.
Still worried about the carb spacing not being the same as the head.
