Proper orientation of float
- Gdizard
21 Mar 2020 11:50Please Log in or Create an account to join the conversation.
Re: Proper orientation of float
21 Mar 2020 11:55
- Gdizard
21 Mar 2020 12:21 - 21 Mar 2020 15:34
Is there a certain measurement tha we can make to make our float height correct before we put our bowl on and use the clear tube method ?
This are vm26ss carbs on a 77 kz1000
Last edit: 21 Mar 2020 15:34 by Gdizard.
21 Mar 2020 15:07
21 Mar 2020 15:26
On VM 28SC carbs I measure as follows: With the carb upside down and the float valve pressed closed I measure from the lip of the bowl to the top of the float. Should be about 16 mm.
- zed1015
21 Mar 2020 16:21
Mechanical float height for those carbs is 26mm from bare gasket face to the bottom of the float.
This is measured with the carb inverted and the float resting on the needle valve.
- Gdizard
21 Mar 2020 17:02
Thank you Rob !
I hope you and your family are staying well !
Greg
Greg
