81 gpz550 Jets with Pod Filters?
  • TruenoboyGPZ550
  • TruenoboyGPZ550's Avatar Topic Author
16 Mar 2020 20:55
#821041
Hi all!
I'm buying a GPZ550 this weekend and I'm super excited. The only problem is that one of the carbs stick and they need a rebuild. They have pod filters and the PO taped around them to reduce airflow because he is sing stock jet size. I found a rebuild kit for 40 bucks on Amazon but my problem is I want to increase the jet size so my friend can tune it properly. I have no clue about buying jets and this is my first bike. I am well versed in cars because I am a tech for Toyota and I constantly play with older carburated cars. But I am new to this and need a bit of a rundown. I have read countless threads and have learned a lot from those.
Basically this what I need to know.
Specs for the rebuild (float level, etc)
A decent kit for the carbs
Jet sizes to use running pod filters
Would it be better to use stock jets and tape the filters like the PO
Any info helps but people who actually have done it I will be especially grateful for
Thank you! Pics of bike below :laugh:
  • riturbo
  • riturbo's Avatar
Re: 81 gpz550 Jets with Pod Filters?
17 Mar 2020 07:25
#821062
Not sure if you saw this yet but start here s3.amazonaws.com/gpzweb/TK22mainPage/TK22mainPage.html
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
  • loudhvx
  • loudhvx's Avatar
17 Mar 2020 09:27 - 17 Mar 2020 09:27
#821081
Also, check the valve train warning in my signature before opening the valve cover.
Last edit: 17 Mar 2020 09:27 by loudhvx.
  • TexasKZ
  • TexasKZ's Avatar
18 Mar 2020 19:56
#821201
You should be able to find he fuel level (not float height) and some other important stuff at this link.
www.kzrider.com/modules/ServiceManuals/Kz400500550_79to83.pdf
