Asking help to identify carburetors
Re: Asking help to identify carburetors
04 Mar 2020 05:19 - 04 Mar 2020 05:20
On further reflection I don't think those are Suzuki carbs. The GS carbs have the throttle stop adjustment on the bottom. Here is a photo of a set that I restored a while back.
BTW, on the GS carbs the pilot fuel screw sits inside the carb body recess. The KZ VM's use an extended section so to speak on the pilot screw so a plastic limiter stop can be installed.
suzuki VM26's
by
nessism
, on Flickr
Last edit: 04 Mar 2020 05:20 by Nessism.
- gd4now
- Denco where did you go?
04 Mar 2020 10:20
After rereading your fist post you did find the following ID 450 and 90. To the best of my knowledge this ID would indicate they came stock on a Suzuki. Will have both air and pilot screw.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
