TK 22 Float Gauge
TK 22 Float Gauge
18 Feb 2020 12:40
Does anyone know where to find a float gauge to fit the drain on TK 22 carbs? I've checked Partzilla and Z1E. Neither of them sells it.
The carbs are on a 1981 KZ550 LTD. My Z1B float gauge screw in thingy is too small. I think the TK's have an M8 x 1.0 or 1.25 thread.
- Warren3200gt
Re: TK 22 Float Gauge
18 Feb 2020 12:47
Google m8 hosetail. You can get one in either pitch for a few dollars from any hardware shop. Just add some clear tube.
The following user(s) said Thank You: hardrockminer
18 Feb 2020 12:53
Will try that. Thanks Warren!
18 Feb 2020 14:03
I think all you need is a short pice of vacuum hose that fits the drain nipple tightly fitted into a lager clear hose. Take a look here
s3.amazonaws.com/gpzweb/TK22mainPage/TK2...stmentsAndMaint.html
19 Feb 2020 14:45
Thanks for that link TexasKZ. I can rough set them with that measurement if they are wildly out of whack.
- loudhvx
19 Feb 2020 16:32 - 19 Feb 2020 16:32
Yes, when working properly, the drain screw is also used as a valve to let out gas for setting fuel level, so you all you need is a bit of small hose jammed into a larger hose for viewing. Make sure to let enough flow to get the air bubbles out.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 19 Feb 2020 16:32 by loudhvx.
20 Feb 2020 18:10
I spent a bit of time with the carbs today. One float was about 3 mm too high, which probably explains the weeping bowl seal. The others were fine. I still have to set them with the drain hose. I need some larger clear hose first, as I only have 1/8 inch in clear and I fear it will be difficult to set with a hose that small.
