Early 80s KZ440 Carb Holder Info Required Please
- Fady
28 Jan 2020 23:21
Hi All,
I'm wondering if anyone has a carb holder for and early 80s KZ440 (Part# 16065-1027)?
I you do, can you please measure the inside diameter of both ports and the distance between the centers of the screw holes and post for me?
TIA
Fady
TIA
Fady
- Elsebu
Re: Early 80s KZ440 Carb Holder Info Required Please
31 Jan 2020 10:21
Are you making a "inlet manifold" ? I can get you the measurement maybe later this day.
- Fady
31 Jan 2020 13:12Elsebu wrote: Are you making a "inlet manifold" ? I can get you the measurement maybe later this day.
Yes mate, that would be great if you could.
- Elsebu
04 Feb 2020 11:43
Sorry, was not able to get all the measurements, my new ones were to big from the carb side propbly from an bigger kz.
Distance between bolts is 64mm an that is the only accurate measurement i can give you for now.
The following user(s) said Thank You: Fady
- Fady
04 Feb 2020 13:08
Thanks mate, it all helps.
04 Feb 2020 14:39
I could have sworn that somebody recently posted detailed drawings of both the early and later carb holders for the 400/440 twins. Have you tried searching the forum?
- Fady
04 Feb 2020 22:30TexasKZ wrote: I could have sworn that somebody recently posted detailed drawings of both the early and later carb holders for the 400/440 twins. Have you tried searching the forum?
I did find him, but he didn't have any of the info anymore,
