Carburetor intake boots
  • Wagner
  • Wagner's Avatar Topic Author
02 Jan 2020 03:45
#816292
I have a 1981 Kz550LTD that I am restoring. I noticed the intake boots are very hard. My question is, should I try and soften the intake boots with wintergreen or should I just replace the air box and intake boots with POD filters. If I go with the POD filters what type should I use and will I have to change jets in the carburetor? Thanks
  • zed1015
  • zed1015's Avatar
Re: Carburetor intake boots
02 Jan 2020 04:14
#816293
You mean the intake tubes from carb to air box ?
I would try and keep them especially if you have got CV carbs as you will never get it to run right with pods and CV's.
  • hardrockminer
  • hardrockminer's Avatar
02 Jan 2020 05:06
#816294
You can still buy them from Kawasaki, or from Partzilla here...
www.partzilla.com/catalog/kawasaki/motor...-cleaner-80-81-c1-c2
  • martin_csr
  • martin_csr's Avatar
02 Jan 2020 06:58
#816298
Z1Enterprises.com has the airbox ducts. see ad link above. I'm pretty sure the KZ550 Ltd uses the same ducts as the 77-80 KZ650 models.
02 Jan 2020 08:56
#816299
Just replace the boots with new ones. Ed
  • Wagner
03 Jan 2020 02:58
#816367
Thanks everyone. I ordered new carburetor intake boots from partzilla.com.
