CV Carbs
- zachsnacks
CV Carbs
15 Dec 2019 08:26 - 15 Dec 2019 08:26
Need to replace my carbs on a 440 Ltd 1983, CV 32's, instead of bringing an old ebay set back to life, are there any brand new oem specs or replacement carbs that you recommend?
Thank you,
- Zach J
Thank you,
- Zach J
1983 Kawaski 440 Ltd
I promise I wont make it a cafe racer if you help me out.
Last edit: 15 Dec 2019 08:26 by zachsnacks.
Re: CV Carbs
15 Dec 2019 11:13
I've read where some people use VM 30's. I think refurbishing your old carbs would be easier path though. What's wrong with them?
- zachsnacks
Re: CV Carbs
20 Dec 2019 16:30
Long story short, I had a cracked jet housing. The part the jet threads into, I put JB weld on it, with the intention of eventually changing them once I figure out why the bike wont rev past 4000, see other threads.
But I just found out the Jets in the 440 are to the west germany spec, instead of the US spec in the manual.
1. How can I confirm the bike is not from West Germany?
2. There is a US labelled jet sizing, and jet sizing that is unlabelled. Which do I go with?
To change the jets I am going to need to break that JBweld seal, hence my need for new carb.
Re: CV Carbs
21 Dec 2019 06:24 - 21 Dec 2019 10:21
No eBay APP ID and/or Cert ID defined in Kunena configurationHow do you know the jets are the west german spec? From the numbers on them?
I would consider getting a good used set of carburetors, then rebuilding them & install new diaphragms from JBM Industries.
Or you could get a new carb body off of EB. Here's one that looks pretty good, but I have no idea if it's correct for your 440.
A set of new carburetors I saw are over $300, plus you'd have to do some fettling, hence the suggestions.
Last edit: 21 Dec 2019 10:21 by martin_csr.
Re: CV Carbs
21 Dec 2019 08:38
West German spec jetting should be fine. Hopefully you have the full complement of jets.
That carb martin posted seems like a good find. Just make sure it's the same type as you need.
Re: CV Carbs
21 Dec 2019 10:33 - 21 Dec 2019 10:34
Just an FYI. From the 80-82 KZ440 factory service manual, the west german models had CV32 carburetors & the others had CV36; and the west german jetting seems to be richer. US models typically had lean jetting because of EPA regs.
The KZ400.com site has the manual plus a number of carburetor service bulletins in regards to the 440D models.
Warning: the forums there may harm your computer, but the tech pages seems to be fine.
Last edit: 21 Dec 2019 10:34 by martin_csr.
- zachsnacks
Re: CV Carbs
21 Dec 2019 17:38 - 21 Dec 2019 17:40
All jetting is accounted for, even the plugs. The diaphragms are also both new frmo a month ago, because I found them both to be ripped.
So I am keeping the german jetting.
Can confirm it was german spec by the numbers stamped on the jets.
Last edit: 21 Dec 2019 17:40 by zachsnacks.
