Can you run vm 28's without the accelerator pump
- mike1957
26 Oct 2019 13:35
I rebuilt the accelerator pump after I noticed the small nozzle on carb #1 wasn't spraying fuel. Tried cleaning it with carb cleaner, a brass brush, air compressor, opened the float bowl the passage was clear up to that small pin hole where it should squirt fuel and no luck. I was thinking larger main jets would compensate for not using the accelerator pump ? Has anyone had this problem ? any help would be appreciated. Thanks Mike
mike1957
Re: Can you run vm 28's without the accelerator pump
26 Oct 2019 14:06
There was a thread a couple weeks ago about deleting the pump on some 650 VM24's. Several people said it's possible and even recommended.
The pump is to cover up for lean jetting when wacking open the throttle quickly. Don't think the main jet is what you need to change. Maybe the pilot or lift the needle.
The following user(s) said Thank You: mike1957
- zed1015
26 Oct 2019 14:46 - 26 Oct 2019 15:06
No eBay APP ID and/or Cert ID defined in Kunena configurationSimple answer is YES.
Accel pump is only for quicker response on initial acceleration and is not active at constant speeds so
deleting it will not affect fueling in other areas and a larger main jet is not needed.
You can just disconnect the pump arm at the very least and use as normal VM's.
You should be able to unblock the jet though using a piece of fine wire at the nozzle end or use proper jet cleaners like these - -
Last edit: 26 Oct 2019 15:06 by zed1015.
