What is the stock main jet size for an 81 kz650 csr with 24mm pumpers? Can anyb
- Troy marcum
22 Oct 2019 17:51 #812877
by Troy marcum
What is the stock main jet size for an 81 kz650 csr with 24mm pumpers? Can anyb was created by Troy marcum
Does anybody know what the stock main jet size came installed on an 81 kz650 car with vm24 jumpers?
- Thank you received: 1656
22 Oct 2019 18:05 - 22 Oct 2019 18:48 #812878
by martin_csr
Replied by martin_csr on topic What is the stock main jet size for an 81 kz650 csr with 24mm pumpers? Can anyb
USA models = 92.5 main jets. see table below >> from the 1981 KZ650 FSM. I have the same motorcycle.
Kawasaki service manual. jarlef z650. the 1981 KZ650 pdf manual is in the Files section.
Last edit: 22 Oct 2019 18:48 by martin_csr.
