Carb T-fitting o-rings
- Jasongpz
17 Oct 2019 18:14
I would like to separate the carbs on my 85 GPz 750 for a deep clean, but I can't find the O-rings for the T-fittings. Kawasaki no longer sells them. Can someone tell me the size of the O-rings so I can order them from McMaster Carr?
1985 GPz ZX750A3
Mikuni BS34 carbs
1985 GPz ZX750A3
Mikuni BS34 carbs
1985 GPZ 750 ZX750-A3
1980 KZ 1000-B4
1980 KZ 1000-B4
Re: Carb T-fitting o-rings
17 Oct 2019 18:42
-10 size typically works for BS carb fuel Tee's but I'm not positive about that application. If you have some calipers post up the diameter of the Tee in the O-ring groove and also the ID of the port in the carb that the Tee plugs into and I'll review.
The following user(s) said Thank You: Jasongpz
- Jasongpz
18 Oct 2019 06:48
Thanks for the info. Can't post pictures as I haven't taken it apart yet. I was hoping to have all the parts in hand so I could finish up the deep cleaning in one day. I will definitely document the size and update when I make the repair.
1980 KZ 1000-B4
1980 KZ 1000-B4
