I feel like an idiot...
  • kevan
  • kevan's Avatar Topic Author
11 Oct 2019 12:34
#812265
First Kawasaki KZ1000. It is a 1979 ST in pretty good shape other than the fuel system being totally corroded. I am doing a carb cleaning and was using carb cleaner and sometimes my compressor to blow out orifices. I blew out the opening where a fuel line connects between the float bowls and something shot out like a bullet across my garage. I looked in one of the other float bowls to see that I was now missing and it is a small brass cylinder held in by a little spring clip.
I do not see the part on any exploded diagrams and it is not included on any carb rebuild kits that I have found.
Can anyone tell me the name of the part and what it does?
The carbs are Mikuni with a pump. I will also try to post a photo...
  • davido
  • davido's Avatar
Re: I feel like an idiot...
11 Oct 2019 14:34
#812268
Is this what youre talking about ( Nos 46 to 49)
www.cmsnl.com/kawasaki-kz1000e1-shaft-19...25.html#.XaD1DmaxXIU
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
The following user(s) said Thank You: kevan
  • kevan
11 Oct 2019 22:10
#812290
That is it! Thank you so much! Now I just need to order one. I had no idea that there was a metal ball in that as well.
I really appreciate the direction! I have been so slow to rebuild the carb and I am really looking forward to hearing this bike run!
  • hardrockminer
  • hardrockminer's Avatar
12 Oct 2019 05:17 - 12 Oct 2019 05:20
#812295
It is part of the setup to provide a shot of gas from the accelerator pump when you turn your throttle handle.
Parts #46 to 49 on Partzilla fiche.
www.partzilla.com/catalog/kawasaki/motor...etor-parts-kz1000-b3
Last edit: 12 Oct 2019 05:20 by hardrockminer.
  • martin_csr
  • martin_csr's Avatar
12 Oct 2019 05:46
#812297
The little parts are sometimes listed on EB. Alternatively, the ball, rod, clip & o-ring are included in a K&L accelerator pump kit at Z1Enterprises.com.
