Main jets for 1983 J3 w pods/hotter cams?
- MartyZ1000
06 Oct 2019 21:55
So my 1983 J3 runs well, it has allegedly hotter cams and definately pods with a V&H system, but it is VERY thirsty
with at least a litre per 10 kms normal driving The main jets are ridiculous at 172, someone realy took a shot at the moon and I suspect
this is the main culprit. Where should I start when trying lesser ones, 140?
Re: Main jets for 1983 J3 w pods/hotter cams?
07 Oct 2019 04:04
The following user(s) said Thank You: MartyZ1000
- loudhvx
07 Oct 2019 08:20
The needle position will play a huge part in normal cruising fuel economy. Cruising a highway at 60 to 70 mph, you will only be in the 1/16 to 1/8 throttle range which is affected by the needle more than main jet, but the main jet still plays a part.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
