z1r mikuni 28 mm carb o ring sizes
- david richard
24 Sep 2019 13:42
hi i intend to refresh my carbs and would like some help with the o ring size its tricky to measure as they are quashed,i cant find any info ,thanks david
Re: z1r mikuni 28 mm carb o ring sizes
24 Sep 2019 16:35
cycleorings.com sells a VM26 set that should have at least some of the required parts. If you have some calipers calculating the sizes needed isn't super hard either. I'd order the kit and see what's left over and then do some measuring on what you don't have. I can help you if necessary.
The following user(s) said Thank You: david richard
