2 simple carb questions
  • Charleslabri
  • Charleslabri's Avatar Topic Author
Re: 2 simple carb questions
24 Sep 2019 12:13
#811287
Tonight I’ve got to put my needle clip back @ 4, so I’ll take a pic of the intake ports on the carb
About 8 various model KZ650s..
Running KZs: 0
  • TexasKZ
  • TexasKZ's Avatar
24 Sep 2019 19:24
#811313
Charleslabri wrote: @650ed I dont have the orifice, so assuming the vm26.
@texaskz since my bench tool is on the way, they float slides just need to be a common height? then i can tune to a specific vacuum once i have the tool, yeah?
Yes, for the bench synch,the height is not really important as long as it is small and the same on each carb. Be sure that the idle adjuster is near the middle of its range so you can easily adjust either way when they are reinstalled.. Before the vacuum synch and final fuel mixture adjustments, make sur e fuel heights are correct, using e clear tube method outlined in the factory service manual. . The vacuum synch tool will allow you to balance them all to the same vacuum reading.
  • Charleslabri
24 Sep 2019 20:48 - 24 Sep 2019 22:13
#811314
set the needle clips to 4, and took a pic of the carbs:
this indicate a vm22?
Running KZs: 0
Last edit: 24 Sep 2019 22:13 by Charleslabri. Reason: Adding pic
  • Warren3200gt
  • Warren3200gt's Avatar
24 Sep 2019 23:28
#811316
Those are vm24ss. Do the bench sync and fuel height as previously suggested whilst the are off the bike. Its much easier access.
Z1000J2 somewhat modified!
25 Sep 2019 05:36 - 25 Sep 2019 05:37
#811328
Definitely VM24SS carbs. Ed
Last edit: 25 Sep 2019 05:37 by 650ed.
The following user(s) said Thank You: Warren3200gt
