- Thank you received: 1
Carb 2 Questiom
- Kiddynamite8
21 Sep 2019 20:18 #811160
by Kiddynamite8
1978 KZ650
Carb 2 Questiom was created by Kiddynamite8
Hi everyone, just picked up a 1978 kz650 and have a question. On the bottom of carb 2 there are 2 nipples. The one to the right is draining down a hose. The one to the left is open. Should it be capped? I'm a total noob and appreciate any help. I attached a pic showing the bottom of the carb. Thanks.
1978 KZ650
- Thank you received: 1656
23 Sep 2019 05:19 - 23 Sep 2019 05:29 #811188
by martin_csr
Replied by martin_csr on topic Carb 2 Questiom
Howdy. Your motorcycle has VM24 carburetors w accelerator pump. One of the ports is for draining the carburetors & checking the service fuel level & the drain screw should stop the flow when seated. The other port is the overflow in case the fuel level in the #2 carburetor is too high for whatever reason.
The accelerator pump is a mechanical device that adds a squirt of fuel to each carburetor when you twist the throttle, such as during heavy acceleration. It was added to compensate for a lean condition because of EPA regulations. Each carburetor body has a pump nozzle that projects into the carb bore. You can test the pump by supplying fuel to the carbs, then twisting the throttle >> fuel should squirt out of the nozzles & thru the carb bore without hitting the carburetor walls.
ps: in your pic the pump rod is bent.
Last edit: 23 Sep 2019 05:29 by martin_csr.
The following user(s) said Thank You: Kiddynamite8
- loudhvx
- Thank you received: 1616
23 Sep 2019 07:28 #811199
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Carb 2 Questiom
Some people eliminate the accelerator pump system and just re-jet a little richer (maybe a needle adjustment?).
You might have to google to get details or maybe someone here will chime in, who has done it.
1981 KZ550 D1 gpz.
Other links.
- Kiddynamite8
23 Sep 2019 08:09 #811200
by Kiddynamite8
1978 KZ650
Replied by Kiddynamite8 on topic Carb 2 Questiom
Thanks a lot guys. I appreciate it.
So i guess putting a cap on the left nipple is a bad idea!
1978 KZ650
23 Sep 2019 08:28 #811201
by martin_csr
I would connect tubing & route it behind the engine. Also, to identify which one is which, you could open the drain screw to see which port flows fuel >> that one would be for draining the carburetors or doing the service fuel level check. The other one would be the carb overflow which you do not want to plug.
- Kiddynamite8
23 Sep 2019 11:56 #811211
by Kiddynamite8
