'79 Kz400 LTD Airbox/filter
  • Noreen
  • Noreen's Avatar Topic Author
18 Sep 2019 10:37 - 18 Sep 2019 10:38
#811020
Just picked up a 1979 Kz400 LTD and I'm slowly putting it all back together and getting it to run properly. Current issue is the idle will rev up. Throttle cable is fine but I know the carbs are out of sync. I just can't get it to idle without revving up long enough to fix this. I figured a good place to start is the un attached empty air box.
Pardon my potential newbie question here- but what and how do I shove a filter in this thing? I can't seem to find a way into the box and there's nothing in there. Just two empty rectangular holes in the back and some sort of line into it through the top (I think I saw someone call this a snorkel?)
Any info or starting place for this is appreciated. I couldn't find much on the forums or on kz400.com
Thanks in advance!
Last edit: 18 Sep 2019 10:38 by Noreen.
Re: '79 Kz400 LTD Airbox/filter
18 Sep 2019 12:03
#811023
The actual model designation for the 1979 KZ400-LTD is KZ400-H1. KZ400-H1 is what you use to look up parts, manuals, etc.
Regarding the airbox, take a look at the airbox diagram at
www.kawasaki.com/Parts/PartsDiagram/142890/1979/KZ400-H1
Notice the parts marked 3 and 4 in the diagram. If you look at the parts list below the diagram you'll see those are part numbers 11011-1043 and 11013-1027. If your bike is missing them or any of the other airbox parts you will need to find them. Ebay might be a good starting point for the search.
For a full set of 1979 KZ400-H1 parts diagrams see www.kawasaki.com/Parts/PartsDiagrams/1979/KZ400-H1 . Ed
The following user(s) said Thank You: Noreen
  • Noreen
18 Sep 2019 18:52
#811034
Thank you! Good info! The more I dug into the parts I'm missing the more I realized A LOT of people are missing them and they are pretty rare to find even on eBay.
I think I'm just going to save myself the whole pain and jump into the other pain of re-jetting for pod filters. I already have to do quite some carb work so might as well.
I appreciate your help!
  • Nerdy
  • Nerdy's Avatar
  • Away
19 Sep 2019 19:13
#811079
You could also get a 2-into-1 intake manifold and use a single VM34. No more synching!
11thhourindustries.com/store/#!/Bolt-On-.../20924335/category=0
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
  • Noreen
19 Sep 2019 19:24
#811080
I like the options! Few questions on this- does that attach to the carbs instead of boots going to an Airbox? Also, does the get rid of the need to rejet, or is more of like turning 2 pods into one? (Again, newbie here sorry if I'm missing something rather obvious :) )
  • Nerdy
  • Nerdy's Avatar
  • Away
19 Sep 2019 19:56
#811081
Whoops. I should have called it a 1-into-2. One carb connects to two cylinders.
The manifold bolts right up to the cylinder head ports (without the rubber boots). There should be a gasket and/or some sealant in there, though.
One carb = one air filter (pod), so no worries there. As for the jetting, I think the manifold manufacturer would be able to help. If your bike is otherwise stock, the jetting should be pretty straightforward.
1980 KZ440B
1981 Yamaha XT250H
1981 GPz550
2013 Yamaha FZ6R
  • Noreen
20 Sep 2019 06:02
#811085
Oh now I understand! That sounds like it would make my life easier. Any downside to this?
  • Nebr_Rex
  • Nebr_Rex's Avatar
20 Sep 2019 09:27
#811103
Depends on the carb, slide vs. constant velocity.
And you will have less power than stock.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • Nerdy
  • Nerdy's Avatar
  • Away
22 Sep 2019 09:54
#811172
It makes sense on the surface that having a single VM34 might offer less power than stock, but I've never seen any numbers. How big of a loss are we talking about here?
1980 KZ440B
1981 Yamaha XT250H
1981 GPz550
2013 Yamaha FZ6R
