Throttle sticking
  • Pipes66
  • Pipes66's Avatar Topic Author
Throttle sticking
24 Aug 2019 23:58
#809791
What could be causing my throttle to stick intermittently. The cable routing seems fine. It does it when I’m going straight,I don’t notice till I try to stop at lights or slow down for roundabouts :woohoo:
When it happens I shut the bike off and restart it and all is fine again till next time.
1983 kz750 F1 Ltd Shaft US model
  • Nessism
  • Nessism's Avatar
  • Away
Re: Throttle sticking
25 Aug 2019 04:51
#809793
If it's a matter of the idle hanging and not dropping down that's likely caused by an air leak on the carb or airbox boots. Basically, a lean condition.
  • baldy110
  • baldy110's Avatar
25 Aug 2019 18:26 - 25 Aug 2019 18:26
#809847
Also check the mechanical advancer if it's sticking it will do that.
Last edit: 25 Aug 2019 18:26 by baldy110.
  • 78z1Joe
  • 78z1Joe's Avatar
  • My man cave is my garage....
26 Aug 2019 11:32
#809882
Had the same thing happen to me maybe 5 years ago. Finally found that 1 of the factory screws ( which had yellow Locktite on it) had backed off from the horizontal arm ( which has a groove it’s entire length) which connects all 4 carbs together. It allowed one carb to lag behind, so the return to idle was slow. Didn’t notice it on acceleration, that I remember.
Good luck
Joe
1978 KZ 1000
1982 GS 300 training bike
Previous Rides...
75 RD 350
72 CB 500 Four
72 SL 125
71 CT 70
69 3 1/2 HP mini bike
