Carb refurb
  • Pat L
  • Pat L's Avatar Topic Author
Carb refurb
19 Aug 2019 04:40
#809447
Hello.
I am refurbishing a set of mikuni's 106 9A of a kz 650 1980 f1.
Would anyone here have an exploded drawing, or a link to a website with similar drawings?
Any help appreciated
Thanks .
Re: Carb refurb
19 Aug 2019 06:25
#809450
The following user(s) said Thank You: Pat L
  • martin_csr
  • martin_csr's Avatar
Re: Carb refurb
19 Aug 2019 07:27 - 19 Aug 2019 07:34
#809456
Partzilla also has diagrams & they're easier to use than most places.
Your carburetors are should be VM24s w accelerator pump. The carb nos. you posted aren't really useful.
Z1Enterprises.com should have gaskets. be sure to compare yours as there are 2 or 3 different float bowl gaskets for VM24 carbs. I believe Z1Ent has 2 different styles of starter plunger caps, so get whichever ones look like yours. A metric nitrile o-ring kit will have some of the needed sizes. My HF kit didn't have the starter plunger o-rings, but Z1Ent may have them.
Last edit: 19 Aug 2019 07:34 by martin_csr.
  • Pat L
Re: Carb refurb
19 Aug 2019 08:22
#809463
Thanks very much.
I dont think my carbs are original as they are not pumpers.
I'll look up partszilla.
  • Nessism
  • Nessism's Avatar
Re: Carb refurb
19 Aug 2019 16:46
#809497
This may help... members.dslextreme.com/users/bikecliff/i.../vm_carb_rebuild.pdf
cycleorings.com has a nice kit. Better than most conventional carb kits that come with aftermarket brass parts (which you shouldn't need).
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
Re: Carb refurb
19 Aug 2019 19:09
#809513
The link provided shows vm26 carbs and you do have vm24 carbs . They are very much the same but just keep this fact in mind. As some of the info and parts show in the link will not be the same in your carbs.
The carb # you indicated are to the best of my knowledge stock carbs on KZ650 F1s sold in non US market locations. In the US they do have the accelerator pump.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • Rado74
  • Rado74's Avatar
Re: Carb refurb
30 Aug 2019 00:50
#810082
hi, is it possible to synchronize carburetors teikei tk22 to kawasaki z500? I found the vacuum outlets, not the screw
  • martin_csr
Re: Carb refurb
30 Aug 2019 05:37 - 30 Aug 2019 06:14
#810087
By Rado74: hi, is it possible to synchronize carburetors teikei tk22 to kawasaki z500? I found the vacuum outlets, not the screw.
loudhvx has a motorcycle stuff page with extensive information about the KZ550 & TK22 carburetors.
See links in his signature or link below. The Z500 is probably similar to the 550. The 550 TK22 jetting might be too rich for the 500.
loudhvx links page
Last edit: 30 Aug 2019 06:14 by martin_csr.
  • loudhvx
  • loudhvx's Avatar
Re: Carb refurb
30 Aug 2019 10:38
#810100
The original Z500's came with Tk22 carbs, so they should go right on.
The following user(s) said Thank You: Rado74
