VM 26 Carb Rebuilding Kits
  • Rick H.
  • Rick H.'s Avatar Topic Author
01 Aug 2019 07:06 - 01 Aug 2019 07:14
#808549
I have a '77 KZ-1000A1 and in a few weeks will be attempting to overhaul the carbs on it. I have read lots of great "how to" information on this site regarding this type of project, but what brand of rebuilding kits are you guys buying for this job and where are you buying them from? It seems there are several choices out there but I don't want to waste money on kits that are marginal at best. Also, where can the all metal fuel Tees be obtained for these carbs? Thanks for any help on this....
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
Last edit: 01 Aug 2019 07:14 by Rick H..
  • zed1015
  • zed1015's Avatar
Re: VM 26 Carb Rebuilding Kits
01 Aug 2019 07:34 - 01 Aug 2019 07:36
#808550
I use Japanese Keyster kits supplied by NRP here in the UK but i'm sure there will be a supplier in the US.
www.nrp-carbs.co.uk/
High quality gear that i've used long term and never had a problem with .
Look on Ebay for the tee's or Z1 enterprises etc.
Last edit: 01 Aug 2019 07:36 by zed1015.
The following user(s) said Thank You: hardrockminer
  • hardrockminer
  • hardrockminer's Avatar
01 Aug 2019 08:37 - 01 Aug 2019 08:38
#808551
I use Keyster as well. I get the delux kit from Z1 Enterprises.
It is very important to change out the needle jets and the needles...something most people don't do. You will find a strong improvement in power and in fuel consumption.
Last edit: 01 Aug 2019 08:38 by hardrockminer.
  • Nessism
  • Nessism's Avatar
  • Away
01 Aug 2019 09:37
#808556
I much prefer to reuse the real deal Mikuni parts vs aftermarket, which are routinely of questionable quality. All you should have to replace is the soft parts anyway. Cycleorings.com has a nice o-ring kit and gaskets are available from tons of sources.
  • hardrockminer
01 Aug 2019 10:12
#808559
I've had a hard time finding Mikuni parts. Particularly needle jets.
